shorteddiode
Posted: Fri Aug 10, 2012 1:11 pm Post subject: Sony KDL 52W3000 5 blinks |
The standby light flashes 5 times when the TV is plugged in, and will continue to give the 5 flashes. Pushing the power button the green light comes on for about one minute then the set turns off , I have no sound and no picture or backlights. I checked the voltages and they all are correct except going to the tcon board. I am supposed to be getting 12 volts to the tcon and when checked with the DVMM it bounced between 4 volts and .3 volts. The tcon connects to the FB1 board. The FB1 board is getting the proper 12 volt input voltage. My question is, The service manual says 5 flashes is either a bad tcon or bad screen. If I am not getting the needed 12 volts to the tcon wouldn't I be safe in thinking it is the FB1 board? I think the FB1 is also called the logic board. Every board except the tcon has the proper input voltage. I can provide a link to the service info if needed.
Thanks Everyone |
Posted: Sat Aug 11, 2012 7:41 pm Post subject: |
Tried inserting your own 12 volts in place of Tcon 12 volts? |
shorteddiode
Posted: Sun Aug 12, 2012 2:04 pm Post subject: |
Do I do that at the tcon board? |
Posted: Sun Aug 12, 2012 3:09 pm Post subject: |
shorteddiode wrote: | I am supposed to be getting 12 volts to the tcon |
If YOU say so... |
shorteddiode
Posted: Sun Aug 12, 2012 6:20 pm Post subject: |
No that,s what the schematic says, is it wrong?? |
Posted: Mon Aug 13, 2012 1:09 am Post subject: |
If that's what the schematic (which I can download from elektrotanya - 25.5mb) says, it should be correct. |
shorteddiode
Posted: Mon Aug 13, 2012 8:07 am Post subject: |
That is where I downloaded mine from, if you would like to double check for me, maybe I misread something. |
shorteddiode
Posted: Mon Aug 13, 2012 1:08 pm Post subject: |
I replaced the FB1 (logic) board and it is up and running and 12 volts to the tcon |
