Sony KDL46S4100 - Vertical lines on TV
bobbintb
PostPosted: Mon Jan 16, 2017 7:10 pm    Post subject: Sony KDL46S4100 - Vertical lines on TV Reply with quote
Sony KDL46S4100
I've read a few solutions to vertical lines on TV but mine seems a bit different. I'm almost certain it's a screen issue but I wanted to make sure. I'll include pictures later if I can. I get discolored vertical lines on my Sony KDL46S4100. However, the lines do not go completely top to bottom. I also visually checked for bad components, which is what I usually find. No blown caps or anything noticeable. If I look at the screen with the TV off at the right angle, I can see a difference in shade where the lines are. It's sounds like LCD screen is bad but I wanted a better opinion.
ivtec
PostPosted: Fri Mar 31, 2017 11:01 am    Post subject: Re: Sony KDL46S4100 - Vertical lines on TV Reply with quote
This Sony model # is famous for Bad Panels
