Sony KDL70R557A main board replacement
sanchel
PostPosted: Wed Apr 22, 2015 10:25 am    Post subject: Sony KDL70R557A main board replacement Reply with quote
SONY 70 TV
Model: KDL70R557A
Serial: 6000819
Board: 0160 AC1F0103
A few days ago we have a big thunderstorm and the HDMI ports fried. I found the solution was to change the main board. This TV model is for export. I live in Colombia and it was impossible to find the specific board.
I found looking in internet data from the USA version.
Model: KDL70R550A
Board: 0160 AC1B0101
Comparing both boards the only difference I found is the USA one don't have the cable traditional connection which I don't care because all my connections are HDMI.
Can I replace the damaged board with the USA version?, and if yes what software version I have to use.
Thanks
PostPosted: Wed Apr 22, 2015 7:03 pm    Post subject: Reply with quote
See if your R557A Main board has a similar number as for the R550A Main board: 1-895-402-31 (1P-012CJ00-4010)
http://www.shopjimmy.com/sony-1-895-402-31-a-board.htm
sanchel
PostPosted: Fri Apr 24, 2015 8:03 am    Post subject: Reply with quote
Both boards have the same number (1P-012CJ00-4010).
PostPosted: Fri Apr 24, 2015 10:00 am    Post subject: Reply with quote
It might. If ALL board connectors are the same?
Menus would likely be a little different. Antenna jack seems to be the most obvious difference and you say you don't use that anyway.
You should be able to obtain latest firmware online from Sony.
sanchel
PostPosted: Sat Apr 25, 2015 7:01 am    Post subject: Reply with quote
Thanks
PostPosted: Sat Apr 25, 2015 9:15 pm    Post subject: Reply with quote
Also available for sale on amazon Here:
