Sony kdp51ws550, 10 blinks, then 5 blinks
_Troy
PostPosted: Tue Jun 16, 2009 5:22 am    Post subject: Sony kdp51ws550, 10 blinks, then 5 blinks Reply with quote
I have a sony kdp51ws550 that started out with 10 blinks and then 5 blinks.
I changed both IC"s MCZ001's. The set came on fine then the next time I
turned it on it just blinks its regular 4 blinks and shuts down.This set
doesnt have the g board with the diodes on it. The chassis is a AX-1 . I can
heat the area around the new chips and it will fire back up. Anyone had
anything with this set other than the chips? Im puzzeld on this sucker.
Thanks in advance. Troy
curt wolfe
PostPosted: Mon Jun 22, 2009 10:57 am    Post subject: Reply with quote
have changed the vertical ic after the 2 ic's didn't fix the problem
