Gray_ Guest
Posted: Wed Aug 06, 2008 10:54 am Post subject: SONY KDS-R50XBR1 |
This one - I need a second opinion on if anyone can verify for me. This set works perfect except - it has a yellow cast to everything - you can see it really well on a blank screen and it actually is move pronounced in the middle up and down - almost looks like a line - but blends outward to the sides. It's there on all inputs including tuner. My thought is the light engine on this one. Any opinions? |
Rick_ Guest
Posted: Wed Aug 06, 2008 10:54 am Post subject: |
I would agree with that assumption...as well....
Optical engine has developed a problem
Good luck.... |
Ed_ Guest
Posted: Wed Aug 06, 2008 10:59 am Post subject: |
Those optical engines will get ya everytime.
Ya ever drop one on your foot? ouch. |
Dewayne_ Guest
I agree that you do have a bad light engine. Sony calls them opticac blocks. |
Gray_ Guest
Posted: Wed Aug 06, 2008 11:00 am Post subject: |
Well, I was pretty sure it was that, because in most of these sets, any
discoloration is caused by the light engine, but this is the first sony lcd
so I wanted to make sure I was still on track. |
Rick_ Guest
Part number goes by serial number becareful before you order...
Guide below should help you. It is from the site...I would even verify
with Sony before hand...This is the guide that I use when I order them...
See ya...
OPTICAL BLOCK ASSY PER SERIAL NUMBER:
A-1148-155-A (ALL UNIT WITH SERIAL# 9000001 TO 90XXXXX & 9800001 TO 98XXXXX)
A-1168-495-A (ALL UNIT WITH SERIAL# 9100001 TO 91XXXXX & 9900001 TO 99XXXXX) |
Mike_ Guest
yellow tint on an LCD projector is most certainly the failure of the blue
LCD panel. Im going to stick with the good old CRT. :) |
David_ Guest
Posted: Wed Aug 06, 2008 11:01 am Post subject: |
It would be nice if they made the lcd panels available. They are not that
hard to take out once you get the optical engine out. |
Posted: Wed Aug 06, 2008 11:39 am Post subject: |
Hold up the horses fellas.
Sony has extended the warranty period on this model regarding light engines untill October 31, 2008 regardless of purchase date.
Contact Sony with your Model and Serial number at 1-866-850-8674
Why pay for this when you can get it for FREE!!!!
