Sony KLV-L32M1 dim screen?
Mattylad
PostPosted: Sun Dec 11, 2011 2:14 pm    Post subject: Sony KLV-L32M1 dim screen? Reply with quote
Hello, can someone please advise on a repair of a Sony KLV-L32M1 LCD tv?
It currently has a very dim screen, the picture can be seen but with no backlight. There is also a flicker in the screen.
I have the service manual however my previous repairs have been on CRT monitors and TV's not LCD.
Does anyone know of a common issue with these TV's, or suggest where I may look to find the fault?
I have confirmed that the 105v, 30v and 16.5v rails are working.
Thank you,
Matty
CelicaSupra
PostPosted: Wed Dec 14, 2011 8:50 am    Post subject: Reply with quote
If theres definitely no backlight, then the thing id check for is power going into the inverter board with the set on. If as I suspect there is power then the inverter board would be the likely culprit & if not then either the PS or mainboard, although as to which I think youd need to further diagnose
