techdiff
Posted: Thu Aug 13, 2009 1:07 am Post subject: Sony KP-57WS500 8-blinks replaced D-board now 6-blinks HELP! |
I've got a Sony KP-57WS500 57" projection TV that had color bleeding (convergence?) on the left side then it would eventually have a red flash and shut off and display 8-blinks (T8005 faulty- D board). I picked up a Sony KP-43HT20 43" with 6-blinks (+5 line overloaded/shorted A, B boards) and used its D-board on the KP-57WS500 and IT got the 6-blinks! Any idea what the problem would be? Or any ideas which parts to check/replace/swap next??
Any help would be greatly appreciated!
Thanks! |
techdiff
Posted: Thu Aug 13, 2009 1:26 am Post subject: |
Could the red tube be going bad? Would that cause it to blink 8 times (T8005 Fly-back transformer)? |
techdiff
Posted: Thu Aug 13, 2009 9:58 am Post subject: |
That list of error codes is not the right list for my TV. I've got the service manual. I listed the error codes for the errors I'm receiving (8-blinks T8005 fly-back transformer board D, 6-blinks +5 line shorted/overcharged board A, B)
Do you think a bad red tube could cause this? Do you know which tube is the red one by chance?
Thanks! |
Posted: Thu Aug 13, 2009 10:22 am Post subject: |
so, initially the red was shifted and staying in the same place? or was it bleeding, and varying in intensity? |
techdiff
Posted: Thu Aug 13, 2009 6:31 pm Post subject: |
It was just blury up at the top left corner of the TV, but the TV would work fine. Then it would eventually flash red all over then shut off and blink 8 times.
I put the original D board back in )with 8-blinks) and removed the HV wire going to the red CRT coming from the HV distribution block, and it works fine (other than no red obviously). I tried switching the red CRT from the 43" TV into it and hooked it up, but the whole screen is red then and the other two CRTs don't display.
Sounds like both red CRTs are bad? |
Posted: Fri Aug 14, 2009 10:04 am Post subject: |
There is a problem with confusion and compatability when you mix sets. Your 57 inch uses three different CRT's and none are the same as the 43 inch set. Also, if you changed out the yokes with the CRT's you are creating possible (though not likely) yoke current problems.
I would suggest you put all of the original parts back into the 57" set and work to resolve the problems.
If I follow this right you most likely have a bad convergence amp on the original 57" D board. Since I did not see the original problem there are two other possiblilities. You could have a bad video amp on the red crt. You could also have a bad G2 block. G2 blocks are famous for failure on this set causing the problem you describe.
TV-TECH-NEWB
Posted: Tue Jul 06, 2010 9:46 am Post subject: Replace the RED Crt Tube. |
To check if its good or bad.
Disconnect the Red CRT.
Leave the yoke in it.
Turn it on and see how long it stays. on.
If it flashes a different color and shuts off..
do the same thing with that CRT and start all over again.
The red CRT might be taking too much power and shorting it out.
I had this same issue before.
I replaced the Fly back transformer and a few other parts.
the last one being a CRT tube.
Sucks but you gotta start somewhere.. |
TV-TECH-NEWB
Posted: Tue Jul 06, 2010 9:49 am Post subject: Re: Sony KP-57WS500 8-blinks replaced D-board now 6-blinks H |
I have the RED Tube for
Sony KP-57WS500
$150
Let me know if you need it.
joe@xbox360professionals.com |
