sony kp-57ws500 CRT board resistor burning
ocandkaren
PostPosted: Tue Aug 14, 2012 7:33 pm    Post subject: sony kp-57ws500 CRT board resistor burning Reply with quote
i have a sony kp-57ws500 57 in. and one of the resitors on the red crt board keeps burning out what
PostPosted: Wed Aug 15, 2012 6:23 pm    Post subject: Reply with quote
Does it continue to "burn out" this resistor when TV is tried with red CRT board unplugged and safely "floating"?
ocandkaren
PostPosted: Wed Aug 15, 2012 6:34 pm    Post subject: Reply with quote
It happens every time we plug the wire from the green crt board to the red crt board? Like its suppose to be plugged up
PostPosted: Wed Aug 15, 2012 6:47 pm    Post subject: Reply with quote
Which resistor? Location/ID number?
ocandkaren
PostPosted: Wed Aug 15, 2012 6:50 pm    Post subject: Reply with quote
R7115
ocandkaren
PostPosted: Wed Aug 15, 2012 6:55 pm    Post subject: Reply with quote
We even bought a new red crt circuit board and it burned out the same one
PostPosted: Wed Aug 15, 2012 7:46 pm    Post subject: Reply with quote
Will the set run (with the green & blue CRT SOCKET/BOARDS plugged in but NOT the red) even for a short time? I'm not sure if IK will prevent. Try allowing to run for 30 seconds (for heaters to come up), turn off and immediately turn back on and see if a bluish-green picture appears.
Resistor is 1,000 ohms at .5 watts.
I suspect you have a shorted red CRT. Probably Heater to G1, which would explain why "It happens every time we plug the wire from the green crt board to the red crt board."
ocandkaren
PostPosted: Wed Aug 15, 2012 7:57 pm    Post subject: Reply with quote
It works with the green and blue one. How do we test the red crt. Heater to g1
PostPosted: Wed Aug 15, 2012 8:10 pm    Post subject: Reply with quote
Leave the red CRT SOCKET vacant and if wires are long enough plug the red BOARD onto the green or blue CRT (AFTER installing a good 1K resistor on the red board). If still bluish-green, Red CRT is defective.
