robfacs
Posted: Fri Aug 13, 2010 1:55 pm Post subject: Sony KP-57WS500 Disconnect High Voltage wires |
I am working on a Sony KP-57WS500. How wll i disconnect the high voltage wires from the HV coils? I've been pulling them out so hard (with the rubber boots off already) but they won't come off. Help is very much appreciated.  |
Posted: Fri Aug 13, 2010 3:43 pm Post subject: |
Have you ever removed a bayonet-based lamp? Well this is similar. Grasp wire, push inward, rotate CCW 1/4 turn, pull outward. |
robfacs
Posted: Fri Aug 13, 2010 6:55 pm Post subject: Thank you!!! |
JTS1957, You're definitely right. After reading your instructions, in 15 seconds, it's off the socket. I'm ready to discharge the tubes to ground. Again, thank you for the quick response. |
