SailorJerry
Posted: Fri Jan 29, 2010 11:19 am Post subject: Sony KP-61HS10 Replaced ICs; Still has Bad Picture |
I have a Sony KP-61HS10 when I first turn the tv on the, picture is scrambled and if I leave the tv on for about 20-30 minutes it will clear up and when I hit flash focus the picture comes in nearly perfect. Although after the picture comes in nice and focused and I bring up the tv menu and the menu is jittery but the program on tv is not jittery. So I thought that this was a convergence issue so I replaced the convergence chips but, the tv is doing the same thing after the ICs where replaced. So I am thinking that there are some resistors and or capacitors that still need to be replaced. Does anyone know which ones need to be replaced or what the problem could be still?
The ICs that I put in it are STK392-040
Thanks!  |
Posted: Fri Jan 29, 2010 11:29 am Post subject: |
looks like vertical circuit problem to me. |
SailorJerry
Posted: Fri Jan 29, 2010 12:03 pm Post subject: |
Im not real familiar with televisions what does that mean or how could it be fixed? |
Posted: Fri Jan 29, 2010 1:17 pm Post subject: |
nevermind, it can't be the vertical if the OSD (on screen display) is showing |
SailorJerry
Posted: Fri Jan 29, 2010 3:04 pm Post subject: |
Do you think it could possibly be a resistor or fuse bad after replacing the ICs? I checked the fuses with a multimeter on the ohms setting and it gave me a small amount of resistance meaning that they are good is that correct?
Thanks |
