Sony KV-27HS420 Red, Green, Blue lines
Inkedivxx
PostPosted: Wed Oct 27, 2010 11:19 am    Post subject: Sony KV-27HS420 Red, Green, Blue lines Reply with quote
Have this Sony set, it has a single red, green, and blue line at the top of the screen. There are only 3 lines. Almost looks like vertical retrace. The vertical circuit seems to be operating correctly. The set has a full picture and the picture looks great other than the 3 lines at the top. I want to say it is the WY board (A-1415-602-A). Any other suggestions or has anyone encountered this problem?
Thanks in advance.............
Inkedivxx
PostPosted: Wed Oct 27, 2010 11:21 am    Post subject: Reply with quote
By the way......The lines appear on all inputs.
PostPosted: Wed Oct 27, 2010 12:45 pm    Post subject: Reply with quote
I'd still check all electrolytics in the vertical output circuit and power sources that feed it. If you have another output IC, try it.
Inkedivxx
PostPosted: Wed Oct 27, 2010 12:47 pm    Post subject: Reply with quote
THanks JTS.....I will try that.
