lscadams
Posted: Tue Feb 21, 2012 1:24 am Post subject: SONY KV-27TS27 - Great picture, static-y/no sound |
SONY 27" TV
Model KV27TS27
Hi, I have a Sony KV27TS27 TV I just got from my Dad who hasn't used it for many years. My problem with the TV is similar to this post:
http://www.riddledtv.com/forums/sony-kv-27ts27-distorted-no-sound-t456.html
But "the part that you're looking for" posted by kuhurdler could no longer be found & "the area to look around" posted by silv is also no longer available to be viewed.
I know this is an old TV, but the picture is beautiful. Can you tell me if the TV is too old to fix? Will I be able to find the part I need to fix it? Any help anyone can provide would be greatly appreciated!!! |
Joined: 28 Dec 2006 Posts: 2878 Location: Overland Park, KS
Posted: Tue Feb 21, 2012 7:49 am Post subject: |
the part you're looking for looks like THIS
you can replace it with two capacitors, as I previously described in the post you linked to. The only downside to that modification is that it will disable SAP, which you likely do not use anyway. |
lscadams
Posted: Tue Feb 21, 2012 2:59 pm Post subject: |
At the risk of sounding like an idiot, what do I put in the search field on radioshack.com to get "2 caps (4.7 uf,50 volts)"?
Thank you so much for posting the link for the part I'm looking for!!! |
Posted: Tue Feb 21, 2012 3:27 pm Post subject: |
"4.7MF" |
lscadams
Posted: Wed Feb 22, 2012 9:53 am Post subject: |
I have to wait until my brother-in-law can help me open the TV. I bought the 2 caps you mentioned from Radio Shack yesterday, so I'm anxious to try your trick. I'll let you know how it goes  |
lscadams
Posted: Wed Feb 22, 2012 9:08 pm Post subject: Sound Fixed!!! |
My wonderful brother-in-law replaced the SBX1637 with the 2 capacitors I bought from Radio Shack as you described in the other post. He had a bit of trouble removing SBX1637, but ultimately he was able to remove it with couple of new tools he had to buy. After everything was put back together, still no sound. I was so disappointed because I was so sure your instructions would work. Then it dawned on me that I turned the TV speaker off because it was making static-y sound. After I turned it back on, VOILA! sound came out of the TV! THANK YOU SO MUCH for your time & for your help! You & my brother-in-law are both AWESOME!!!  |
Posted: Thu Feb 23, 2012 1:50 pm Post subject: |
glad it worked, thanks for posting back. |
Dark Angel
Joined: 13 Jan 2009 Posts: 21 Location: Santa Ana, CA
Posted: Sun Mar 18, 2012 2:41 am Post subject: |
@kuhurdler
Sorry to post here but wasn't sure if I should post here or in my thread.
Anyway I was wondering if you or someone else could tell me what value the caps are as I was thinking of maybe replacing them and see if I could bring the module back to life.
So far from what I have gathered from the pics I have seen I have been able to get these value's:
The seven connector pins of the sound board are on the left side of the module.
Top 3 caps: 47mf/50v : .47mf/50v : .47mf/50v
2 Middle caps: 4.7mf/35v : 4.7/35v
Bottom 3 caps: 4.7/35v : 4.7/35v : 4.7/35v
Again I ask if you or someone else can verify the cap values I listed.
Thanks for your time and anyone else who can help me. |
Dark Angel
Posted: Sun Mar 18, 2012 5:39 pm Post subject: |
I am aware that it would be easier and quicker to do that, but I like a challange and need more practice on my soldering skills anyway.
Thank you though for the reply and the link as I will keep that in mind as an alternative. |
