SONY KV-27TS32 DEAD
raakbanu
PostPosted: Fri Jul 29, 2011 11:33 am    Post subject: SONY KV-27TS32 DEAD Reply with quote
First I want to thank Jim for this excellent TV repair form.
My 27 Sony TV with AA-1 or SCC-F84E-A chassis is dead for quite some time. I do have schematic for this TV.
I found Q591, Q601, Q602 were shorted between C-B-E & R607 was open.
I replaced all of the above and TV worked fine Very Happy . After for 40 minutes a bright vertical line appeared on the screen and immediately went blank and dead Shocked .
From the above symptom, I understand that some other component(s) in the horizontal section is caused to fail above components. If FBT is bad/short it would not allow TV to operate for 30 to 40 minutes.
Any help for my issue?
PostPosted: Sat Jul 30, 2011 2:10 pm    Post subject: Reply with quote
Resolder horizontal driver TRANSFORMER pins.
raakbanu
PostPosted: Sat Jul 30, 2011 7:43 pm    Post subject: SONY KV-27TS32 DEAD Reply with quote
Thanks for your suggestion. I need to order two set of parts later. I will try your suggestion and post the result later.
Do you think I need to check any other components? besides resoldering Hor. Driver Xfmr?
