SONY KV-27XBR55
nick
PostPosted: Mon Dec 20, 2010 3:35 pm    Post subject: SONY KV-27XBR55 Reply with quote
Note picture defect in screen image below
Is there a relatively simple fix?
What component is in need of repair/replace?
Suggestions?
Thanks
PostPosted: Mon Dec 20, 2010 4:08 pm    Post subject: Reply with quote
Nice pictures.
problem: vertical IC. Probably a bad electrolytic capacitor.
Does it make any difference if it warms up for a while, or if you tap on the screen with the side of your fist?
nick
PostPosted: Mon Dec 20, 2010 5:26 pm    Post subject: Reply with quote
Horizontal lines present from power on. No matter what source, does not seem to change much at all after on for hours.
Light to very firm "tapping on screen with the side of fist" does nothing.
Do I need a BFH? (Bigger Hammer) LOL!
Can I locate problem and replace component electrolytic in Vertical IC or is it time for $$$hop or junk?
Thanks...
PostPosted: Mon Dec 20, 2010 7:19 pm    Post subject: Reply with quote
Sams #2958
Check: C555; C502; R502 & IC500.
Be sure IC500 Pin 2 = 13.4VDC & Pin 4 = Minus 17VDC
