Sony kv-32fs120 Schematic
mountainman
PostPosted: Thu Oct 01, 2009 10:12 am    Post subject: Sony kv-32fs120 Schematic Reply with quote
Looking for location of the G board and D647, D690 and Q605, Thanks
PostPosted: Thu Oct 01, 2009 10:58 am    Post subject: Reply with quote
Physically "look" at the boards. Thats assuming of course that you have eyes that work Laughing Laughing
Seriously, the identification of the boards is printed on the boards themselves and the component ID's are also printed on the boards.
The "G" board is located on the left side!! (looking from the rear)
mountainman
PostPosted: Thu Oct 01, 2009 11:17 am    Post subject: Reply with quote
Hi, thanks for responding. Looking from the rear I have a large board on the bottom labeled A. no board to the left but there is a vertical bd. off this bd. labeled M. on the left side of this A bd.
PostPosted: Thu Oct 01, 2009 11:37 am    Post subject: Reply with quote
My bad!!
I looked it up, there is no G board on this set. Usually only projection units have a G board.
What gave you the idea that there should be a G board and What makes you think that the listed components are bad?
Better yet, give the symptoms you are experiencing and lets go from there.
mountainman
PostPosted: Thu Oct 01, 2009 1:59 pm    Post subject: Reply with quote
I'm getting 9 blinks and the set will turn with the service menu code. I have a couple posts that have been answered here and that's where I got the idea on the parts. The G bd. idea came from another forum but no one could helpany further. So right there is not a Gbd. on my unit.
PostPosted: Thu Oct 01, 2009 10:09 pm    Post subject: Reply with quote
Replace D647.
I had the same set that would not start. LED was blinking 9 times. I could start the TV by entering the self diagnosis mode, Display, 5, Volume Down, Power. Parameter 9, ZCD, was always greater than 000, even after clearing error codes (8, Enter). Changing D647 solved this problem. I used a 1N4937. The Sony part number is 6-500-567-01, Diode, 10ERB20-TA1B2. It's part of the Zero Crossing Detect circuit.
mountainman
PostPosted: Fri Oct 02, 2009 8:40 am    Post subject: Reply with quote
JTS1957 wrote:
Replace D647.
Any hint on which board this is on ? Thanks
PostPosted: Fri Oct 02, 2009 1:38 pm    Post subject: Reply with quote
"A" board - front center- next to transformer.
Replace even if tests OK. Wink
mountainman
PostPosted: Fri Oct 02, 2009 3:25 pm    Post subject: Reply with quote
Thanks I've been working on this for a month! Very Happy
paulm
PostPosted: Sun Nov 17, 2013 4:38 pm    Post subject: Reply with quote
JTS1957 wrote:
Replace D647.
Just wanted to say thanks for this info! My father-in-law has a Sony KV32FS120 that wasn't turning on and showing nine blinks on the timer LED. Searching google lead me to this thread and I was able to fix the tv by replacing D647 and D645. Both measured ok, but I replaced them anyways and now it works again!
Thank you!
