Sony KV-34XBR910-power supply died- 3 flashes
daguroo
PostPosted: Thu Jan 28, 2010 9:48 pm    Post subject: Sony KV-34XBR910-power supply died- 3 flashes Reply with quote
Poor novice working on own tv. Power supply progressively weakened (it took 50 times of pushing power switch to turn on) until it would not turn on at all, then it sent 3 flashes. I figure it is HV Regulator went bad then triggered IC6505 to go bad. I cannot find IC6505 and need pointers on how to check and replace parts, ie., chassis assembly removal (pg. 10 in ser. man. says to lift up and rotate---rotate up I guess?), how to find IC6506, and have not been successful with discharging CRT with suggested method on Riddled. Also I cannot find HV Reg. part # in service manual (why?)
daguroo
PostPosted: Tue Feb 09, 2010 1:59 pm    Post subject: and the solution was----- Reply with quote
FIX: IC 6501 and IC 8002 on D board behind fly.
Geo Magnet
PostPosted: Tue Feb 16, 2010 7:49 am    Post subject: Or buy my DZ board Reply with quote
I have a DZ board for a KD-34XBR960 in perfect condition. Make you life easy for $50.
daguroo
PostPosted: Tue Feb 16, 2010 10:59 am    Post subject: Reply with quote
already fixed
