Sony KV36XBR450 problem with A board
mronaldo
PostPosted: Mon Sep 28, 2009 11:25 am    Post subject: Sony KV36XBR450 problem with A board Reply with quote
Hi
My KV36XBR450 has a defective A board. I'm sure it's the A board because I tested this board in another TV and got the same sintoma.
Every time the favorite or PIP buttom is pressed the picture turns small and curved at sides. Also when a strong signal is present at any video input (only video input, not with RF input)
When this happen, the only way to reset is disconecting from wall.
And then does't keep memory. It comes back on even if was turned off before disconecting from wall. Also looses all settings.
I hope I can get any good tip from you guys, because is too expensive to replace the board.
Ronaldo
