tellyman
Posted: Tue Feb 19, 2013 2:47 pm Post subject: Sony KVM1421U sound problem |
Can anyone suggest a cure for a "golden oldie"?The set is a Sony KVM1421U which is being used with a PVR connected via the scart input.The problem is the sound will start to break up and come and go and eventually disappear.This will happen a couple of minutes after switch on.The sound will come back on and off at different levels.No amount of freezer and hair dryer treatment helps.Any help would be great. |
Posted: Wed Feb 20, 2013 1:51 pm Post subject: |
This sounds like the makings of a bad tuner, but you indicated it was through the SCART input. So in that case, it's probably a bad solder joint. |
Posted: Wed Feb 20, 2013 9:09 pm Post subject: |
If thinking AFT drift (AFT detector coil adjustment), the tuner picture would have to be affected too, but as he states its via scart. |
tellyman
Posted: Thu Feb 21, 2013 1:20 pm Post subject: |
Just an update guys on the fault i have.I have eventually traced the fault to C012 a 22uf capacitor connected to Q005 base and R045 on the print side damaged because of leakage.Thanks for the interest. |
