Sony LCD KDL-32M3000 slow refresh rate
Gabe
PostPosted: Tue Jun 16, 2009 5:08 am    Post subject: Sony LCD KDL-32M3000 slow refresh rate Reply with quote
This tv seems to be soo slowwwwwwww
It act like the refresh rate is 2 seconds instead of 5 milliseconds.
Everything works but picture appears slowly .
If I press menu , it appears about one second later. If I plug signal in , picture looks like those effects when you took heavy drugs Smile
I really don't have any idea about this trouble.
Checked a lot of components , especially caps , all good.
It is really a refresh rate problem, tv act very very slow.
Any input welcome.
_Tony
PostPosted: Tue Jun 16, 2009 5:09 am    Post subject: Reply with quote
Check LVDS wire to the tecon board unplug and plug it back in at both
ends. I just Had a Visio that would scan lines slowly or give menu
with a ghost menu the picture just did not stack up in the right
locations. Your problem is probaly in the main board though .
Dewayne
We have seen the LCD panel cause this. The likely cause is the t-con which can only be obtained from Sony with the panel.
