Sony LCD KDL-40S3000 13 blink code   Goto page 1, 2  Next
_LIsa
PostPosted: Sun May 03, 2009 6:12 am    Post subject: Sony LCD KDL-40S3000 13 blink code Reply with quote
This set has a 13 blink code. I can't find a code for this set that goes this high. Has anyone seen this before? Thanks, Lisa
_Rick
PostPosted: Sun May 03, 2009 6:12 am    Post subject: Reply with quote
Balancer error....
this is the WAX3 Chassis....
Sony training manual # CTV41
_John
Rick I know your a busy Man, but can you expain
what a Balancer is for those of us that have not heard of this.
Thank you
John
_LIsa
PostPosted: Sun May 03, 2009 6:13 am    Post subject: Reply with quote
replaced invertor board, no help. Doe's this mean that the LCD panel is bad?
_Rick
Lisa...
Does the panel light breifly
then fade out?
I had one recently similar
panel and model and the panel
would light just briefly then fade
out and all signs pointed toward the inverter
but in the end it ended up being the B
board....for the set i had trouble with...
If the set you have does not light at all
and following the tiage flow chart I sent you
the panel could be the problem....
before condeming the panel make sure
you have exhausted all the troubleshooting
options on that guide I sent you...
the Sony triage guides are not perfect
but they can be of some good assistance...
in your previous mail you never mention
if the panel lights or not..
_Lisa
PostPosted: Sun May 03, 2009 6:14 am    Post subject: Reply with quote
Yes the back light lights for a few secounds , then i get the 13 blink code
. I will try the B board. Thanks, Lisa
DeWayne
You possibly have a bad balancer board but most likely have a bad LCD panel.
_LIsa
replaced invertor board [ balancer board] no change. Lisa
_DeWayne
PostPosted: Sun May 03, 2009 6:15 am    Post subject: Reply with quote
Then the LCD panel is your problem.
_Gabe
Is there a hidden warranty on those sony panels ??
Something like 3 years..... it does ring a bell ....
Goto page 1, 2  Next
Page 1 of 2
