Sony Trinitron KV-20S40 messed up color.
Rayzer
PostPosted: Sat Jun 29, 2013 9:26 pm    Post subject: Sony Trinitron KV-20S40 messed up color. Reply with quote
I have a Sony Trinitron, KV-20S40, 20". This morning it started not working so well. At first when I turned it on, the screen was black longer than usual with the red standby light blinking like it usually does when turned on, only for 10 seconds longer than usual. When it did eventually turn on, the sound was fine but the color was all messed up. It's as if the brightness and/or contrast has been drastically altered, it's way too dark. But those settings are not the problem, I did check and adjust them a bit in the hopes of fixing the image. I'm guessing some part wore out to some degree. Is it even worth fixing it or should I just get a new TV? thank you.
