Sony TV KV-27FV310
_Terry
PostPosted: Tue May 12, 2009 3:55 pm    Post subject: Sony TV KV-27FV310 Reply with quote
This TV is dead except that the LED flashes a dozen times then speeds up, stops a few seconds then blinks 2 times then stops starts every 1-2 second intervels. Any ideas?
_Bob
PostPosted: Tue May 12, 2009 3:55 pm    Post subject: Reply with quote
Terry ,Measure collector voltage of Horiz output transistor when first turn on it should check 135 volts breifly.If it is low and checks 60 to 80 volts unsolder collector of HOT and see if it comes up when first turn on.If it does flyback probably bad.but if you have briefly 135 volts on collector of HOT. Then i woluld replace IC8002 MCZ3001DB these ICS go bad all the time.Also IC702 TDA6108 on picture tube socket module sometimes will short out and cause the set to immediately to shut down.You can unsolder the IC or pull the plug on CRT board and see if it stays on .Hope this Helps Bob
_Bob
PostPosted: Tue May 12, 2009 3:56 pm    Post subject: Reply with quote
Terry ,If remember right you won't get 135 volts on collector on Hot if IC8002 MCZ3001DB is bad.But these MCZ3001DB go bad alot.
_Terry
I have this TV running but it has a narrow pix with slight pin cushioning.
Just got manual but if anyone has a suggestions I'm open for one, thanks.
_J
PostPosted: Tue May 12, 2009 3:57 pm    Post subject: Reply with quote
I think we are missing something here, your first post said the set
was dead. I saw nothing about you getting it running. That makes it a
bit hard to follow.
_terry
I think I did say it is running except that the pix is narrow and horiz. &
stretched vertically. I still haven't got to the problem. B + is 135V.
horiz. freq. is right.
_Terry
PostPosted: Tue May 12, 2009 3:58 pm    Post subject: Reply with quote
How I got this set to start up is that the customer or some other tech had
the wiring messed up. I found the right wiring and presto, it came up with
the narrow and stretched vertical raster.
