Sony TV Service Menu Code - Plasma / LCD / CRT / RPTV
Sony
PostPosted: Sat Jul 21, 2007 1:44 am    Post subject: Sony TV Service Menu Code - Plasma / LCD / CRT / RPTV Reply with quote
# Using the remote control:
# Turn the TV off.
# Press {DISPLAY} {5} {VOL+} {POWER ON} buttons.
or
Press {DISPLAY} {5} {POWER ON} buttons.
# The Service Menu will be displayed.
# Use numbers {1} and {4} to select the item to adjust.
# Use numbers {3} and {6} to adjust the value of the data.
# Press {MUTE} then {ENTER} to save new settings.
# The words "WRITE" in red will show up in the upper right corner if saved.
# Turn the TV off to exit the service menu.
Sony
PostPosted: Sat Jul 21, 2007 1:44 am    Post subject: Service Menu Access Reply with quote
PROJECTORS :
* Service Menu :
* Using the remote control
* Press {ENTER} {ENTER} {UP ARROW} {DOWN ARROW} {ENTER}.
* Then {UP ARROW} when it asks: "Do you want to enter the Service Mode?".
* Factory Mode :
* Press {ENTER} {ENTER} {LEFT ARROW} {ENTER}.
* Then {UP ARROW} when it asks: "Do you want to enter the Factory Mode?".
* Any additional menus usually pop up under the main INFORMATION menu.
Sony
PostPosted: Sat Jul 21, 2007 2:04 am    Post subject: Service Menu Key Sequence Reply with quote
* Access "Menu" and make sure "Status" is On.
* Exit the "Menu".
* Service Menu :
* Select "Yes" when it asks: "Do you want to enter the Service Mode?".
* Factory Mode :
* Select "Yes" when it asks: "Do you want to enter the Factory Mode?".
PostPosted: Tue Jan 07, 2014 8:08 am    Post subject: Reply with quote
DISPLAY 5 VOLUME UP POWER ON - GETS YOU THE SERVICE MODE....DISPLAY 5 VOLUME DOWN POWER ON - GETS YOU THE SELF CHECK
(copied from Curtis Wolf Post here)
