sonykp-53v80 just installed new crts, need alignment
Wendell1980
PostPosted: Sat Nov 22, 2008 12:18 pm    Post subject: sonykp-53v80 just installed new crts, need alignment Reply with quote
got new crts in now i need to get them adjusted, possibly alignment data would be helpfull
PostPosted: Sun Nov 23, 2008 4:30 pm    Post subject: Reply with quote
It does not work quite that way,
Did you do a full convergence before replacing the CRT's?
Was the alignment ok before changing the CRT's??
If it was, you will have to go into the Service Menu and make sure that the Green gun is properly centered, oriented (straight and not tilted left or right) and correctly focused.
Have you ever converged a set from within the service menu before??
Wendell1980
PostPosted: Mon Nov 24, 2008 7:36 am    Post subject: Reply with quote
the convergence on the set was fine before i had replaced crts, and the alignment was fine too.
I had taken notes on the position the yokes where etc,
the green is almost centered i just need to turn its yoke slightly left.
and to answer the last question this is the first time i have replaced crts on a projection set. have done it on tube tv's with no probs.
I have been in the service menu looking around so far thats it.
would be my first time to try to converged a set from within the service menu
