bmontgomery
Posted: Mon May 30, 2011 9:55 am Post subject: Sylvania LC370SS9 is completely dead. |
My Sylvania LC370SS9, 37" LCD TV is completely dead, No lights, noise or anything. I already removed the rear cover to the check the fuse and its fine (0.5 ohms). beyond the fuse I don't know what I'm looking at. I have noticed that when I plug the TV in, I hear a small pop and see a small arc as if there's a considerable load on the circuit. I'm new at this so any help would be greatly appreciated. |
Posted: Mon May 30, 2011 10:47 am Post subject: |
No "Puffed Lytics?"
Check for bad diodes on power supply.  |
bmontgomery
Posted: Mon May 30, 2011 4:50 pm Post subject: |
thanks I'll do that, |
bmontgomery
Posted: Tue May 31, 2011 6:12 am Post subject: |
I have also found there is 170 VDC on the large red/black wired connector, does this mean the power supply is fine and some other board is bad. |
Posted: Tue May 31, 2011 6:20 am Post subject: |
IF raw B+ were the only voltage on a particular power supply. See if edge connectors are marked for voltages. |
