Sylvania LC420SS8 two green blinks back to standby
colin5656
PostPosted: Sat Mar 06, 2010 2:06 pm    Post subject: Sylvania LC420SS8 two green blinks back to standby Reply with quote
Make: Sylvania 42 lcd
Model: LC420SS8
MFG Date : 10/07
Problem: Push power green blinks twice back to red, set does not come on
Tried: Have correct voltage from wall removed cover have power to ckt board. saw fuse removed checked with continuity tester fuse ok visually looked over boards no obviously burnt components
My Skills: I have repaired pinball board (bridges caps optos transistors resistors ETC...) not afraid to solder Fami;lar with the use of a Multimeter.
Thanks in advance to anybody who could possibly help
PostPosted: Sat Mar 06, 2010 8:08 pm    Post subject: Reply with quote
Found:
If set has faint high pitched sound, try D604. Cool
colin5656
PostPosted: Mon Mar 08, 2010 8:27 am    Post subject: Reply with quote
Set has faint high pitch sound. tested d604 on board with DMM black on banded side reading of .559 should be good but should I remove a leg and test again
PostPosted: Mon Mar 08, 2010 12:18 pm    Post subject: Reply with quote
If you had this set while it was working properly or even if you did not it is possible a bad or broken panel will cause this problem on this set.
It is easy to check this. Disconnect the panel from the digital pcb and the backlights will light. This will tell you if you have a panel problem.
