Sylvania LCD TV LC320SS9 A non-responsive.
Latourious
PostPosted: Fri Dec 20, 2013 7:05 pm    Post subject: Sylvania LCD TV LC320SS9 A non-responsive. Reply with quote
The TV was working fine one day, and now it's not. When I press the power button the light will flick to green for about five seconds before a humming noise comes from the back for about four more seconds, then it proceeds to turn off. Well, turn off isn't exactly right. The screen never turned on in the first place, just the power indicator. The TV also doesn't completely die, it will switch to standby (red LED).
Now, I've taken the back panel off to try and discern where the hum is coming from. I have two culprits. Either the capacitor or the yellow object (not sure what it is) beside it.
http://postimg.org/image/5grum0djt/
(Sorry for the bad quality)
Based off of a little research it seems like the capacitor needs replacing. I should mention that there are no burn marks or burning smell coming from it, nor is the top rounded. It seems fine, really, but I've no experience in this field.
Thanks to all replys and help.
PostPosted: Fri Dec 20, 2013 7:44 pm    Post subject: Reply with quote
A shorted (leaky) diode or possibly a open inverter transformer winding or even a bad digital board. Wink
Latourious
PostPosted: Fri Dec 20, 2013 8:08 pm    Post subject: Reply with quote
How would I go about figuring out if it's one of the things you mentioned? Are they even something I would be able to fix myself?
PostPosted: Fri Dec 20, 2013 8:40 pm    Post subject: Reply with quote
A DVM can test many parts. Start with the diodes around/near the humming item.
IF in doubt, pull the part out, at least enough to isolate it from other components it may be in parallel with.
http://www.wies-hs.eu.dodea.edu/Courses/PTS/Electronics/ComputerServiceSupport/css/Forms/Doc/EleTstGD.pdf
