Sylvania SSC132 TV/VCR need info
_Al
PostPosted: Tue Jun 16, 2009 5:16 am    Post subject: Sylvania SSC132 TV/VCR need info Reply with quote
Can someone tell me if the SSC132 is the same as the SSC192? I have a 192 manual but not a 132. The problem was wouldn't turn on. Found shorted Zener D615 replaced it and set turned on then Diode shorted again. Found the feedback transistor had bad solder. Set wouldn't start then after resolder. Checked Horizontal waveform and it looked good. Check vertical and there was none. Found open resistor to vertical IC. Probably when the power supply went high. Now the set comes on but the channel buttons switch from AUX to CH1 to menu. Is there a reset technique for this? Meanwhile I'm going to take the buttons and remote sensor out and see if that helps.
_Paul
PostPosted: Tue Jun 16, 2009 5:17 am    Post subject: Reply with quote
I think you're done. That sounds like normal operation for that combo.
If you go ahead and do an autoprogram, you should have your channels, and
everything's cool. The menu access in between AUX and channels might go
away after setup, I can't remember.
