auroch
Posted: Thu Apr 16, 2009 10:56 am Post subject: Symphonic 27" 2003 WF2703 thin white lines at top |
For a couple of months now, thin white lines have been appearing at the top of my television screen. They've gradually grown more pronounced, and occasionally cause a sort of inverted reflection. This effect really mucks with some of my 360 games, so I'd like them stopped. Someone suggested this:
"The vertical output IC is operated from a scan driven power supply. these supplies, while efficient, run at high frequency. Thus, the filter capacitors tend to run hot when their ESR changes. This is not at all an uncommon problem to TV repair professionals.
The simple solution is to resolder the output IC itself, and change the power supply capacitor - or capacitors, and the problem will go away, parts will cost about a couple bucks."
If this is truly the case, any suggestions on how I go about doing this?
Thanks in advance.
PS: Here's a photo.
Posted: Thu Apr 16, 2009 2:17 pm Post subject: |
c532 47mfd @ 35volt |
auroch
Posted: Thu Apr 16, 2009 4:35 pm Post subject: erm... |
Whilst I'm sure you meant well.. I'm going to need a little clearer directions. It's not enough to know what component, specifically, as I'm not very solder savvy. |
Posted: Thu Apr 16, 2009 6:02 pm Post subject: |
C532 is the "location" of the most likely (not necessarily ONLY) component that has been known to cause the problem you describe.
The boards are usually marked (top & bottom) with the "location" numbers of most components. You should find this part near the Vertical Output IC (IC551; LA78041 which is mounted on a heat sink).
You will have to be able to unsolder/remove/install/ and resolder this part.
If you are unfamiliar with any "terms" or "proceedures," do a search. "You Tube," for example, will show unsolder/soldering videos; "Google," etc. for where to obtain replacement part.
Posted: Thu Apr 16, 2009 6:04 pm Post subject: |
Well,
If you post a good picture of the chassis it could be pointed out or you can simply get a good light and read the component location (C532) that is printed on the circuit board. It will be close to a fairly good sized heat sink.
It is a little round thingy that stands up on the circuit board, it is covered with plastic, has 47ufd @ 35VDC printed on it, and has it's little silver head showing through on top. LOL.
The chassis is easily removed and if you do not have the soldering skills, I am sure you could find someone that does have these skills to solder in the new component for you.
Good Luck
Sorry about the ribbing, I guess I am simply in a good mood today (Taxes are paid) |
auroch
Posted: Thu Apr 16, 2009 7:01 pm Post subject: |
Alright, thanks to both of you. I think I can wing it from here.
EDIT: Okay, scratch that, I'm going to have plenty of questions in the near future. Stay tuned. |
kc8adu
Posted: Wed Apr 29, 2009 6:42 am Post subject: |
iirc this is a funai chassis.
had one here with vertical issues and one of the supplies to the output chip was low and had smps hash on it.
open 1000@16 in the power supply.
someone else had shotgunned it and the common offenders had already been replaced. |
