Thin Vertical colored lines Emerson LC320EM8
an0n
PostPosted: Thu Feb 05, 2009 9:08 pm    Post subject: Thin Vertical colored lines Emerson LC320EM8 Reply with quote
I own an Emerson 32" (I think model : LC320EM8 )
A few months ago (literally just out of warranty) Dark Vertical lines began appearing on the LCD Screen but would disappear after a 1/2 hour of being on.
Then the amount of lines began to increase; but will eventually disappear. Now the lines have begun to stay indefinately. They thin out a but (and have different hues of color [yellow/ green/ red/ etc]).
The TV is only worth $450 New. This one is almost 2 years old.
Is this a cheap repair shop job?
Is this fixable for me to do myself? Depending on equipment needed I am sure if it is fixable I can do it with proper instruction.
thanks
CraigMan
PostPosted: Mon Apr 13, 2009 7:31 pm    Post subject: Any luck with your problem? Reply with quote
I have the same problem with the same TV. Were you able to fix yours? If so, where did you take it?
