Thomson TV Service Menu Codes
Thomson
PostPosted: Sat Jul 21, 2007 1:49 am    Post subject: Thomson TV Service Menu Codes Reply with quote
* With the TV in standby:
* Press and hold the {VOL -} & {PRG -} buttons on the TV.
* Keep both buttons pressed until the TV turns On with the Service Menu displayed.
* To exit, turn the TV Off.
Thomson
PostPosted: Sat Jul 21, 2007 2:02 am    Post subject: Service Menu Key Sequence Reply with quote
* While the TV is On, press the {POWER} button on the remote control to put TV in standby.
* Turn the TV Off using the {POWER} button on the TV.
* Using the buttons on the TV:
* Turn the TV On while pressing the {PRG -} & {VOL -} buttons
* The Service Menu will be displayed.
