TIT china TV is not working
ElEc_TrOn
PostPosted: Tue Apr 28, 2009 10:24 am    Post subject: TIT china TV is not working Reply with quote
HI,
I have tit tv
yesterday, it was working and then it has turned off without any visible reason.
standby led is working but screen goes of immediately
see this video:
http://tinypic.com/player.php?v=wlrb14&s=5
ElEc_TrOn
PostPosted: Tue Apr 28, 2009 10:35 am    Post subject: Reply with quote
if the above video is not working see this:
http://electrical.net.googlepages.com/tit.wmv
PostPosted: Tue Apr 28, 2009 1:46 pm    Post subject: Pays to buy the best Reply with quote
The area between the yoke plug and ?vertical? output IC looks discolored in your photos. Check solder joints, especially in that area.
The video does indicate (white flash) that you do have high voltage while set tries to power up. (set's not set to an aux input, is it?)
ElEc_TrOn
PostPosted: Tue Apr 28, 2009 10:23 pm    Post subject: Reply with quote
In the back of the mainboard there is circular area that has brown soldering points.
I will resolder them .
Thank you Smile
ElEc_TrOn
PostPosted: Thu Apr 30, 2009 3:41 am    Post subject: Reply with quote
I re-soldered that area but still same problem
any idea?
PostPosted: Thu Apr 30, 2009 6:59 am    Post subject: Reply with quote
Start by checking for dc voltages on secondaries (diodes) of the Switched Mode and the scan-derived power supplies.
