Toshiba 23WL56G service menu code   Goto page 1, 2  Next
jcv06
PostPosted: Thu Sep 15, 2011 6:35 am    Post subject: Toshiba 23WL56G service menu code Reply with quote
Dear friends
I am trying to adjust the video of my Toshiba 23WL56G. Unfortunately, the 'mute' 'mute' 'menu' code does not work. Any idea about a working code for it?
Thank you in advance for your help
JC
PostPosted: Thu Sep 15, 2011 9:35 am    Post subject: Reply with quote
There's two other codes you can try on this page below the one you mentioned
jcv06
PostPosted: Thu Sep 15, 2011 11:07 am    Post subject: toshiba 23WL56G Reply with quote
Hello there,
Firt of all, thank you for your quick reply. Ufortunately, these two codes you specified do not work neither !!!! I can't see anything alse to try. The good old time of potentiometers !!!!!
PostPosted: Thu Sep 15, 2011 4:32 pm    Post subject: Reply with quote
Try:
enter the main menu by pressing M button and then press the digits 4,
7, 2 and 5 respectively.
jcv06
PostPosted: Fri Sep 16, 2011 12:57 am    Post subject: toshiba 23WL56G...... again !!! Reply with quote
thank you again for your reply,
JTS1957, I have ryed the 4725' code but this does not give access to adjustments.
Regards
JC
PostPosted: Fri Sep 16, 2011 2:08 am    Post subject: Reply with quote
What, about the video, are you wanting to adjust?
jcv06
PostPosted: Sat Sep 17, 2011 1:56 am    Post subject: Reply with quote
Hi jts1957 (??)
I got some prblems with vertical lines, showing blinking dots. horizontally. I would like to send you some picture of it. If you have any e-mail I can send it, you should understand better. I was told that using some play boxes may be the reason of adjustment changes of vertical/ horizontal, brightness ........
Anyway, it is very nice you try to help me (sorry for my English but I am French !!)
PostPosted: Sat Sep 17, 2011 6:05 pm    Post subject: Reply with quote
kuhurdler wrote:
If you would like to post a picture but don't know how, please email the picture to
forumpicture@riddledtv.com
Just tell us which post to attach the picture to, (which means you have to already have created a post)
PostPosted: Mon Sep 19, 2011 8:19 am    Post subject: Reply with quote
uploading these per your request.
PostPosted: Tue Sep 20, 2011 7:19 am    Post subject: Reply with quote
I presume upper pix is 90 degrees CCW from normal viewing position? If so, streaks are on left of ALL objects? Or just objects on the right side of the screen?
You could try reseating your LVDS cable. Otherwise I seriously doubt that any adjustments will eliminate the streaking. Appears more like a defective board.
Goto page 1, 2  Next
Page 1 of 2
