Toshiba 27a33 retrace lines
1968RT
PostPosted: Sat Jan 22, 2011 3:27 pm    Post subject: Toshiba 27a33 retrace lines Reply with quote
Toshiba model 27a33 made in Nov 2003
Screen shows what appear to be retrace lines 2 inches in height at the very top of the screen. Lines appear on all inputs, but seem to disappear on some channels.
PostPosted: Sat Jan 22, 2011 8:21 pm    Post subject: Reply with quote
C406, C407 or C408 are likely candidates.
1968RT
PostPosted: Sun Jan 23, 2011 10:53 pm    Post subject: Reply with quote
Looks like that did it! I can't narrow down for you which cap it was, because the position of the 3 caps in relation to each other and other components and heatsinks I found it easiest to remove all 3 caps at once and just replace all three (had them all in the spare parts bin anyway).
Thanks, you came through for me again. I appreciate you sharing whatever resources you seem to have at fingertips or in your head with me, and also your time.
alyna
PostPosted: Mon Jan 24, 2011 6:38 am    Post subject: thanks Reply with quote
I learned from you... Thanks for the idea. Sometimes overvoltage at grid can cause retrace to appear. Changing caps is one of the best additional...
PostPosted: Mon Jan 24, 2011 11:50 am    Post subject: Reply with quote
You must work on some VERY OLD sets.
