TOSHIBA 27AF43 D515 Shorted
miar56
PostPosted: Sun Oct 03, 2010 5:57 pm    Post subject: TOSHIBA 27AF43 D515 Shorted Reply with quote
TOSHIBA 27" TV
Model 27AF43
Chassis M3N127T
The TV was working fine the last time it was used but during a storm the electricity went out. When the electricity came back on the TV would not come on. After taking the back off and plugging it in the TV makes a low high pitched squeal. This indicates something is shorted. Checking the diodes in the switching power supply found D515 shorted. I don't have the schematic. For starters looking for the part # or a cross reference to this diode. The designation on the PCB indicates that it is a zener.
Thanks for your help
PostPosted: Sun Oct 03, 2010 7:49 pm    Post subject: Reply with quote
Location #: D515
TSB P/N: AD300670
Reference #: D97U01501B
Desc.: Diode Zener MTZJ15B T-77
15 volt .5 watt
miar56
PostPosted: Mon Oct 04, 2010 3:45 am    Post subject: Toshiba 27AF43 d515 Reply with quote
Thanks for the quick response. I will get one, try it and let you know what happens.
miar56
PostPosted: Sun Oct 10, 2010 6:01 am    Post subject: Reply with quote
OK that was it. It's working fine. Thanks a lot for the help
