Toshiba 32a35 gradual vertical collapse
nce1111
PostPosted: Sun Nov 16, 2008 8:00 pm    Post subject: Toshiba 32a35 gradual vertical collapse Reply with quote
Toshiba
32" crt 32A35
the set is three years old.. first started as vertical rollover went away on warm up.. now will not expand completely.. seems like a bad electrolytic cap possibly vertical output ic? just hoping someone can point me in the right direction or actually is familiar with the set.
Thanks...
Nick
PostPosted: Sun Nov 16, 2008 9:20 pm    Post subject: Reply with quote
IC401 = Vertical output IC = LA78041
Electrolytic caps in the order of likely cause of problem is
C407 = 100UFD@35VDC
C409 = 10UFD@50VDC
C408 = 1000UFD@25VDC
C406 = 1UFD@50VDC
Starting at dead center of pcb and going to the front you will bump into a heat sink that contains IC401. The Electrolytics are in and around this heat sink.
nce1111
PostPosted: Mon Nov 17, 2008 10:11 am    Post subject: Reply with quote
thanks a lot.... exactly what i was looking for!
