Toshiba 32A40 - Won't start working until smacked !
bluetooth
PostPosted: Mon Jun 15, 2009 5:32 pm    Post subject: Toshiba 32A40 - Won't start working until smacked ! Reply with quote
Hello,
I have a Toshiba 32A40 TV set, which was working great until recently. Since a month ago, it won't turn on, by which I mean no audio or video, or the display and sound would turn off suddenly while I am watching TV. When I smacked the set on the sides (upper end), it would work normally. It has been going on like this for a while now, and many times it takes several smacks before it comes on. The things I noted are:
1. If I turn the TV on, the power LED comes on, but the audio/video may not be on.
2. When it does not turn on, neither video nor audio work
3. Also, when it does not turn on, if I change the channel using the remote control and then smack the TV, it shows the new channel that I steered the TV to using the remote.
4. The locations on the set that I smack to make it work are, sides of the TV, the back of the TV, especially on and around the board where all the cable connectors are.
Since the TV works when I smack it, I thought it might be the I took the risk of opening the set, but did not see any lose connections.
I would appreciate any suggestions experts on this forum might have.
Thanks
PostPosted: Mon Jun 15, 2009 8:21 pm    Post subject: Reply with quote
Still a BAD joint - ?tuner?
TonyC1
PostPosted: Tue Jun 16, 2009 6:46 am    Post subject: Similar problem - found loose component Reply with quote
I had a tv with same prblem - it wa an easy fix - opened it up - found a loose component attached to a heat sink - all three solders were loose - soldered it up - has be working like a champ.
