bosanci28
Posted: Thu Jan 14, 2010 9:38 pm Post subject: toshiba 32HL67 video image moves in slow motion |
TOSHIBA REGZA 32HL67
i have this tv and everything works on it,,except is showing video image in slow motion
i have checked all ports in with a dvd player and all is the same,
changed the video board, and still same problem..
any ideas?
thanks |
Posted: Fri Jan 15, 2010 6:57 am Post subject: |
Can you explain this a little more. I have never heard of anything like this. |
bosanci28
Posted: Fri Jan 15, 2010 11:09 am Post subject: |
well,the tv works fine,,
the only think the video/picture,,
let say you looking at a show the people in the video are moving in slow motion,, they not moving normal,,
they moving very slow,,
is like when you watch a movie and you fast fowrd,or slow fowrd..
moving in motion...like robotz..
thanks |
Posted: Fri Jan 15, 2010 1:51 pm Post subject: |
You are kind of describing a bad panel.
Test: press menu on your remote: move around within the menu screen: is the effect still there on the menu?
If it is you most likely have a bad panel.
Also: try something other than a dvd player. (possible DVD Failure???)
bosanci28
Posted: Fri Jan 15, 2010 2:10 pm Post subject: |
i have try on multiple dvd players,and dvd disks,
also on regular tv channels
i also played with the menu settings to see if anything is off/on
also replace a new video board and still the same,,
bad panel?,,what exactly is that,,the control board?
thanks |
Posted: Fri Jan 15, 2010 3:36 pm Post subject: |
Ok, without actually seeing what you are talking about only one thing comes to mind.
My description of what I have seen is this.
As images move they leave a trail as though the picture is slow in refreshing. Example: If the Letter A was the only thing on the screen and you moved the letter 1 inch to the right you would see at the moment of movement multiple images of the letter A with the original position fading out and each successive image of the Letter A would in turn fade out untill only the last image is left.
When a set does this it is called response time and is almost always a bad Panel.
The panel is the part that you touch when you touch the screen.
bosanci28
Posted: Thu Jan 28, 2010 5:24 pm Post subject: |
can you explain little better ,,is that the screen (panel-outside)_ or the screen inside where is connected to the board?
thanks |
Posted: Fri Jan 29, 2010 11:15 am Post subject: |
Inside/outside = one and the same. This is the most expensive part of the set and many times the wholesale price is higher than the retail price of the set
