Toshiba 32ZD98B - picture problem - SOLVED
polyfusion
PostPosted: Sun Jul 25, 2010 11:56 am    Post subject: Toshiba 32ZD98B - picture problem - SOLVED Reply with quote
Toshiba 32" CRT
Model 32ZD98B
Chassis 23550853 (possibly?)
SOLVED
PostPosted: Sun Jul 25, 2010 2:46 pm    Post subject: Reply with quote
That's NOT a chassis number. C9SS Chassis
I'd start by getting some good magnifiers and then pulling the chassis and looking over the solder joints, paying close attention to the 1 watt and larger resistors and anything that's attached to a heat sink. Cool
polyfusion
PostPosted: Mon Jul 26, 2010 4:32 am    Post subject: Reply with quote
Thanks for the pointers.
Issue solved.
PostPosted: Mon Jul 26, 2010 2:20 pm    Post subject: Reply with quote
JTS1957 wrote:
That's NOT a chassis number. C9SS Chassis The Chassis number is: C9SS - it was right there on the front cover of the service literature
I'd start by getting some good magnifiers and then pulling the chassis and looking over the solder joints, paying close attention to the 1 watt and larger resistors and anything that's attached to a heat sink. CoolIsn't that what I just said?
polyfusion
PostPosted: Mon Jul 26, 2010 2:53 pm    Post subject: Reply with quote
Got it sorted, thanks.
Issue solved.
PostPosted: Wed Jul 28, 2010 9:20 am    Post subject: Reply with quote
why edit/remove all your posts? how about you leave your problems and solutions here so somebody else can benefit from what you learned?
