jjbanes
Posted: Thu Jul 30, 2009 7:10 am Post subject: toshiba 34hfx85 dead |
i have a toshiba 34hfx85 cinema television that i just got. the guy said it just quit. i can turn it on and then it just goes dead instantly. the red power light comes on and then goes right out. you can hear the tube power up and then shut down. i took the back off and looked at the fuse and it is good. i looked for bad solder joints but didn't see any.
any help would be appreciated. |
Posted: Thu Jul 30, 2009 7:29 am Post subject: |
if you just got it, it should have a warranty. |
jjbanes
Posted: Thu Jul 30, 2009 7:40 am Post subject: |
i just got it for free. it is a 2005 model. |
Posted: Thu Jul 30, 2009 12:37 pm Post subject: |
from "the guy."
I've never heard a "tube" power up. Maybe degaussing you're hearing? |
jjbanes
Posted: Thu Jul 30, 2009 1:07 pm Post subject: |
it makes a noise like a normal tv. you get static on the front for a brief second. then clicks and it is off. when i try and turn it back on the red light comes on and then back off with a relay type noise. it doesn't make static after the initial turn on. |
jjbanes
Posted: Mon Aug 03, 2009 1:09 pm Post subject: |
hasn't anyone ran in to this problem before? i am lost. |
Posted: Mon Aug 03, 2009 8:50 pm Post subject: |
Has High voltage for a moment and then nothing.
Can you try running set at a lower AC voltage (Variac)? |
jjbanes
Posted: Tue Aug 04, 2009 8:28 am Post subject: |
i am new to this. if i put a rheostat in line to the outlet then i could reduce power. how low should i try? |
Posted: Tue Aug 04, 2009 8:30 am Post subject: |
I'm just trying to rule in or out the possibility of a bad regulator. 80VAC. |
