southbrook
Joined: 04 Dec 2009 Posts: 1 Location: preston lancashire uk
Posted: Fri Dec 04, 2009 12:19 am Post subject: Toshiba 37WLT66 Regza Gaming problem |
Hi, I have a 37WLT66 Toshiba Regza which has a strange problem.
When I connect my ps3 via hdmi, on a regular basis I get a green 'haze' on the screen - more so in darker areas of the picture, I have tried different cables and on hdmi 1 and 2 inputs. I then decided to try my xbox360 using HD component input with the same results. Both consoles are 100% fine on my sons Toshiba LCD. I have a cable box connected to the tv via a regular scart which is 100% fine with no signs of this green.
I have spoken to the Toshiba tech support and they cant understand the problem. They advised me to try and get a HD 'broadcasted' tv signal into the set via hdmi to see if the problem occurs, unfortunately my cable tv box is not HD. Also the set is just 2 years old.
Any help would be very appreciated
Thankyou |
