toshiba 42h81 power light on no picture   Goto page 1, 2  Next
makitaman
PostPosted: Thu Aug 28, 2008 5:56 pm    Post subject: toshiba 42h81 power light on no picture Reply with quote
ive got a rear projected 6 yrs old
toshiba model # 42h81
power light comes on can hear speaker cones but no picture
i picked this up from someone who had a tech in the set
and told him the convergence board needs to be replace
i checked all the fuses
found a 1.8 ohms resistor that is burnt and they put 4 2k resistors on the exsiting 1
ive replaced that resistor
they jumpered fuse 852
and unsodered 1 heat sink from board
ive ordered ic chips for it but im thinking its a power issue
i can see the the compound coming out of the side of the stks so it looks like they were replaced cant be positve(doesnt look factory)
i have the same set already that i had to replace the chips on and there was minimal compound on the chips.
ive heard of resoldering jumpers but i dont know the locations.
any ideas
tom
makitaman
PostPosted: Sat Aug 30, 2008 7:51 pm    Post subject: Reply with quote
ive replaced the ic's and still no pic.
and they were definately changed already.
im thinking the flyback is gone.
nervous to start stickin my meter in there.
i have schematics can anyone point me to the best way to meter around in there.
thanks tom
PostPosted: Tue Sep 02, 2008 9:03 am    Post subject: Reply with quote
Do the IC heat sinks get warm??
If they do not, check fuses F852 - 2AMP, F853 - 1.25AMP, F850 & F851 - ALL 5AMP on the power deflection pcb. THESE ARE NOT GLASS FUSES. They are usually about the size of a 1 watt resistor and either green or orange in color. They are soldered in. The nomenclature is printed on the component side of the board. They are all about centered on the opposite edge of the PCB as the high voltage transformer.
If you have cleaned up the mess you describe you most likely have one of these fuses blown.
makitaman
PostPosted: Tue Sep 02, 2008 11:30 am    Post subject: Reply with quote
i have 7 black fuses that i have checked and not found an open
if i can find out where the commons for these fuses i can meter them hot and see the voltage going through them. ive checked the power to the ic's using pin 1 as common and pins 4 and 5 should be at 22 volts and there at .3 volts. which would tell me they are dead.
PostPosted: Wed Sep 03, 2008 9:19 am    Post subject: Reply with quote
I do not know how to describe fuse location any better. See previous post. Just measure DC levels on both ends of these fuses while set is on. Using the tuner shielding as ground.
makitaman
PostPosted: Wed Sep 03, 2008 11:17 am    Post subject: Reply with quote
ok ive tested to all kinds of shields and get nothing on both sides of fuses
but i got voltage on both sides of main fuse
fuse locations i tested were f850 f851 f852 f853 f490 f870 f891
i c 2 more in the high voltage side f860 and f801 that i havent checked yet.
makitaman
PostPosted: Wed Sep 03, 2008 11:51 am    Post subject: Reply with quote
801 is the main and teseted fine
f860 has been tested no voltage either side and is closed
PostPosted: Wed Sep 03, 2008 3:37 pm    Post subject: Reply with quote
The main fuse F801 is on the primary side of the SWPS and is AC (Alternating Current)voltage.. When measuring any of the other fuses you need to be in DC (Direct Current) mode with your meter. F860 must be measured from Hot ground for a proper voltage measurment.All other fuses listed must be measured from Cold ground (Tuner shield etc) and your meter must be in DC mode.
makitaman
PostPosted: Thu Sep 04, 2008 11:33 am    Post subject: Reply with quote
yes i see the main voltage on ac no problem. and on dc to the other fuses i read no voltage using the tuner shield
PostPosted: Thu Sep 04, 2008 1:14 pm    Post subject: Reply with quote
First, When you turn the set on do you hear a relay click. If no relay clicks stop there and advise.
If there is a relay click, check for momentary DC at the fuses for maybe one to two seconds after the click.
Goto page 1, 2  Next
Page 1 of 2
