Christopher
Posted: Mon Nov 24, 2014 8:37 pm Post subject: Toshiba 42hp66 Plasma flickering screen problem |
Please help!
NOTE: I am not a professional tech!
Everything works fine except the flickering.
I am leaning toward replacing the main logic ctrl board.
PART# 6871QCH077C
I do not see any capacitors that look burned or anything.
The only reason I am thinking maybe it is the main board, is because someone on another site posted that it was his problem on a vizio.
Is there anyway to check the board to make sure it is the problem?
Does anyone know for sure what would be causing this?
Any help at all, will be greatly appreciated!
Thanks for reading! |
Posted: Mon Nov 24, 2014 10:01 pm Post subject: |
My vote: Ysus. |
Christopher
Posted: Mon Nov 24, 2014 11:32 pm Post subject: |
JTS1957 wrote: | My vote: Ysus. |
Thanks!
Which of the 2 sustains is the "Y"?
Would you happen to know,if it is on the right or left side from the back on this model Toshiba?(I guess they may be marked, I should have looked?)
What does the y & Z do/control?
Thanks again! |
Christopher
Posted: Fri Jan 02, 2015 5:13 am Post subject: flickering Toshiba 42hp66 |
Does anyone out there know which part is causing this?
All i can find out is that it has to be one of 3 parts, those being:
1) Main Logic ctrl board
2) y-sus
3) z-sus
PLEASE HELP! ANYBODY?
Thanks,
Chris |
