tomgibson
Posted: Tue Jun 28, 2011 8:45 pm Post subject: Toshiba 42hp95 - Are the resistors in this image problem? |
I was watching my 42hp95 the other day when I heard a pop, the screen turned off and I smelled a faint odor of burning electronics. I took a quick look around and the only suspicious looking components I noticed were the two in this picture. Are they the most likely problem? If so, can you tell what resistance the replacements should have? (or that I should be verifying with my multimeter?)
Thank you in advance for any and all help.
Tom
By tsioc at 2011-06-28 |
Posted: Wed Jun 29, 2011 9:28 am Post subject: |
R401 is toast
you'll have to measure with an ohm meter for the 2nd one to find out.
I suspect those are designed to expire because something down-circuit is shorted. R401 is now protecting your TV from starting a fire. |
tomgibson
Posted: Sat Jan 21, 2012 6:41 pm Post subject: |
Sorry for the long delay, but here's a better picture of that resistor. What exactly foes the 55k mean?
Posted: Sat Jan 21, 2012 7:31 pm Post subject: |
.22 ohm resistor.
Don't forget to check the big black transistor-looking thingy to the right. |
tomgibson
Posted: Sat Jan 21, 2012 8:02 pm Post subject: |
I'm drawing a blank on how to check it. It's labeled:
str
f6167
sk 5616 |
Posted: Sat Jan 21, 2012 8:20 pm Post subject: |
IF either end of toasted resistor goes to ANY pin on that device - replace the device. |
Posted: Sat Jan 21, 2012 8:21 pm Post subject: |
whats the screen printed number for that component on the circuit board? |
