Toshiba 42rv530u r850 1.8 resistor blown
kodie
PostPosted: Wed Mar 25, 2015 8:55 am    Post subject: Toshiba 42rv530u r850 1.8 resistor blown Reply with quote
TV resistor was bad, I replaced it blows again, I look at the diodes bridge it's ok, so I was thinking about pfc
curtis wolfe
PostPosted: Thu Mar 26, 2015 10:54 am    Post subject: Reply with quote
FOUND STR-Z2589 REGULATOR IC SHORTED BETWEEN PINS, R850 (5 WATT 1.8 OHMS) OPEN AND 2.5 AMP FUSE F850 OPEN.
kodie
PostPosted: Sun Mar 29, 2015 10:53 am    Post subject: Reply with quote
thanks, I try to check that
PostPosted: Wed Apr 01, 2015 8:35 am    Post subject: Reply with quote
Replace R850, 1.8Ω/7Watt, and relay SR81. Both on the power board
