Toshiba 50HDX82 No Power - Capacitors?   Goto page 1, 2, 3, 4, 5, 6, 7, 8, 9, 10  Next
mshields
PostPosted: Sun Dec 12, 2010 8:37 am    Post subject: Toshiba 50HDX82 No Power - Capacitors? Reply with quote
Okay, Still have the no-power issue. Got into the back of this unit this morning. There are plenty of caps and some of them had some type of fluid around them. It's almost like a silicon glue, but is grey in color. I don't know if this means the caps are bad. I Only saw this on some of the caps, seems like it would be on all of them if it were normal? Let me know if anyone has any clue on this. I have pics but looks like I need a website to post them.
Toshiba RPTV
Model: 5OHDX82
PostPosted: Sun Dec 12, 2010 3:36 pm    Post subject: Reply with quote
If glue is ONLY on the physically largest caps ... normal.
"Silicon glue" would be solid like a caulk - not fluid like a liquid.
mshields
PostPosted: Sun Dec 12, 2010 7:47 pm    Post subject: Reply with quote
Well, it must be glue, it is a Solid Rubber composition. It is also on some of the smaller caps, and two are being glued together. I'm still trying to figure out how to get this set up and running again.
PostPosted: Sun Dec 12, 2010 8:04 pm    Post subject: Reply with quote
No light(s)? No "Click(s)"?
Start with basics. Blown fuse(s)? Raw B-Plus? Stand-by source(s)?
mshields
PostPosted: Mon Dec 13, 2010 5:57 pm    Post subject: Reply with quote
Yes it definitely has the relay click. No light on the front. I have a set of schematics and a training manual I just picked up yesterday. I am going to check out Q801
mshields
PostPosted: Mon Dec 13, 2010 5:59 pm    Post subject: Reply with quote
sorry hit the button too fast. Going to check out Q801 tonight, it says if the resistance is low it is probably shorted.
mshields
PostPosted: Sat Dec 18, 2010 6:41 am    Post subject: Reply with quote
After checking my schematics and training manual it says to check Q801. It is a semiconductor/IC that acts as a Voltage Regulator, the manual says to check resistance between pin 1 and 14 and pins 12 and 14, if the resistance is 3 Meg ohms the part is good, but if it is 10-12 ohms then there is a short. When I measure I get around 6 ohms from pin 1 and 14 and 0.1 ohms from 12 and 14. I am assuming this is the problem with my no-power issue? What do you think? (Also, the IC was measured out of circuit.)
PostPosted: Sat Dec 18, 2010 6:54 am    Post subject: Reply with quote
IF that's how your "schematics and training manual" says to test it, I'd suspect it is bad.
mshields
PostPosted: Sat Jan 15, 2011 6:27 pm    Post subject: Reply with quote
Replaced that IC chip and am still having the same problems. I have the Service manual and Training Manual that I would be willing to e-mail someone if they can help me. Just let me know and i'll send it to you.
mshields
PostPosted: Mon Jan 17, 2011 6:06 pm    Post subject: Reply with quote
Isn't there anyone out there that can give me a hand with this?
Page 1 of 10
