Toshiba 50HP66 Buffer Board
dicepackage
PostPosted: Mon Apr 05, 2010 3:30 pm    Post subject: Toshiba 50HP66 Buffer Board Reply with quote
Model: Toshiba 50HP66
Description: 50 Inch 720p Plasma
Condition: Distorted picture
I have heard that my buffer boards were to blame for the problem I am having with this TV. I have posted some pictures of another TV that is doing the exact same thing.
1. Just to confirm does this appear to be a buffer board issue?
2. Can I buy just the upper buffer board to test it out and if I do so if my bottom buffer board is broken will that damage the top one? My y-sus connects to the upper board and the top board communicates to the bottom buffer board.
Without input
With input
With input
PostPosted: Tue Apr 06, 2010 11:21 am    Post subject: Reply with quote
This is NOT, I repeat NOT a upper or lower buffer problem.
The upper and lower buffers are for Horiqontal sweep, not vertical sweep.
(The lines would run left to right if a buffer problem)
High probability of a bad controller or panel.
Hope this helps.
