Toshiba 50L4300U - 1/3 picture fuzzy
tedparis
PostPosted: Wed May 27, 2015 5:49 pm    Post subject: Toshiba 50L4300U - 1/3 picture fuzzy Reply with quote
the lower 1/3 of the picture gets fuzzy then clear , every couple seconds .
its a smart TV mod # 50L4300U
See picture
PostPosted: Wed May 27, 2015 6:53 pm    Post subject: Reply with quote
TV is obviously smarter than you:
Your search - D23255T12173L1 - did not match any documents. Wink
tedparis
PostPosted: Wed May 27, 2015 7:15 pm    Post subject: Reply with quote
ok its fixed
PostPosted: Wed May 27, 2015 8:19 pm    Post subject: Reply with quote
I'll assume you meant that model number is corrected. Smile
https://www.youtube.com/watch?v=N-h2oezFOB4
Bad bonding of one or more tabs to panel. Try gently twisting panel and or gently pressing around perimeter of panel.
Quite a few examples on YT - this seems most similar:
https://www.youtube.com/watch?v=bvwhQKY9JOE
tedparis
PostPosted: Sat May 30, 2015 5:53 am    Post subject: Reply with quote
Thank you for the help ! I opened up the set and checked what I beleave are the bonding screws , they hold the screen to the frame, as I removed them the picture would change , I replaced the screws and the problem is still there.
The 1st link you posted is the same problem I'm having .
I also posted the problem on FB and was told it maybe the screen . Any thoughts ?
PostPosted: Sat May 30, 2015 10:54 am    Post subject: Reply with quote
1) Replace the TV. Rating: Easy
2) Find and replace the panel. Rating: Hard
3) Find some company that has the equipment necessary to rework the tabs on your panel. Rating: Hard
Easy one involves losing your initial investment, but now, knowing how well today's sets are constructed, you may make a more informed decision towards the purchase of your next set regarding dollars spent versus longevity.
In my opinion, the persons making the decisions asked their designers two questions regarding attaching so many, many connections, 1) Is this the absolute cheapest way it can be done? And, 2) Will an acceptable number fail and have to have their panels replaced at our expense, during our warranty period?
Hard ones depends on whether you can locate #2 or #3 and on what proportion of your initial purchase price you're willing to invest/spend.
tedparis
PostPosted: Sat May 30, 2015 11:38 am    Post subject: Reply with quote
I will post it local for free in someone can use it or trash it
