1gr8sysop
Posted: Fri Sep 24, 2010 7:53 pm Post subject: Toshiba 56HM195 blue blurs and ghosting |
Hi,
I have a Toshiba 56hm195 that has been great for four years, recently the lamp blew. I replaced the lamp a couple of days ago and the tv powers up fine but has a blue blur sometimes. I will try to explain it the best that I can. If there is a white on a black screen you get a blue blur on the right of the white. You also get blue horizontal lines from time to time but they are not exact lines, kinda a blue blur from left to right. also on blue or black screen you get the blue blur to the right even on the menu. I have seen a post on several forums like this with no answer example check out this post "Toshiba 56HM195 blue interference/ghosting" but no answer to what might be causing it. I'm desperate to get my tv working and any help would be greatly appreciated..
Update. working on this problem I have noticed that its worse with the contrast turned up but not the brightness. also its much worse in HD here are some pics.
http://s1108.photobucket.com/albums/h401/1gr8sysop /Toshiba/
Here is a link to some pics |
