Toshiba 57H81 Green screen
peebs
PostPosted: Sat Jan 16, 2010 7:41 pm    Post subject: Toshiba 57H81 Green screen Reply with quote
Hello,
After many years of use the screen of my 57H81 went green. All inputs are affected. After the set is turrned on the display starts getting lines after a short period of time. Just trying to get an idea if this may be reasonably repairable or if I should just put repair funds towards another set. Your help is appreciated.
thank you
PostPosted: Sat Jan 16, 2010 9:13 pm    Post subject: Reply with quote
I would guess its a problem with the Green CRT board.
http://www.riddledtv.com/repair/journal/Toshiba51H84/
If so, it is not a difficult fix. Probably less than $300 for a house call plus parts and labor.
PostPosted: Sun Jan 17, 2010 7:14 am    Post subject: Reply with quote
added picture to your post, per your email request
PostPosted: Sun Jan 17, 2010 3:14 pm    Post subject: Reply with quote
Does set do same on ALL inputs? Could be Hyper board?
peebs
PostPosted: Mon Jan 18, 2010 11:02 am    Post subject: Reply with quote
Thank you for the replys and posting the pic for me. The other inputs start off as blue and then go to green. Eventually the entire picture goes off completely.
